New rob
What is the color of the spring for 02 vmax 600 er (stock )
Yellow green yellow
New rob
My neighbor has www in hers and has always complained about to high of engagement how much of a difference would the ygy make or could ther be other factors ??
www has higher engagement with lower finish than stock. If she likes the finish on the www she can use yellow silver yellow, same finish as www but less engagement. Also make sure your neighbor doesn't have shims in her primary. Also check whole primary over for bad bushings, make sure rollers are good, wouldn't hurt to blow it out with compressed air.
New rob
Will do thanks
