Need help with crank seals
PYD825
MA
Can anyone identify the pieces in the attached photos? When I was replacing the crank seals I found these 2 little man-made pieces in the area of the oil collecting ports on the center bearings with the 2 half moon clips. Any help/advice is greatly appreciated. Thanks!!
I thought that also so I checked not that I looked through book couldn’t find any information they are almost half the size of outer bearing pins
