kurick
Hey guys first post here. Have 2 vipers. One 2004 stock and one 2003 Mtn with bender triple pipes that will not idle. Starts on full choke only and runs great above 2000rpm(with choke off). Once it drops to 1800 it quits, unless I "massage" it back to life. Things I have done: Disconnected TORS. Reeds are good(not chipped). Ohm checked stator, good. Removed flywheel and sanded rust(wasn't bad at all). All new plugs. Swapped coil rack from good running viper. Cleaned carbs 3 times following mrviper's post in the tech section. The pilot circuit is clean. Adjusted TPS(even though I don't know how to set it, I was frustrated and needed to try something after the last carb clean). Makes no difference if the headlight is on high or low beam. 2000ft alt. 165mains. 55pilots. A/F screw 1 7/8. Compression is 100 110 110. A little low but it should still idle? I have a video on my phone I will try to upload, or if someone knows what's up I will email it to them direct. Thanks in advance. This site is great, just not finding that other fella with the same issue that already has a great thread about this.
