Phazer secondary Settings
3phazers
Loudon, NH
Hello All,
Does anyone have a chart, or notes on secondary settings on a 94 Phazer II?
It’s been a few years since I played around with the driven clutch.
I believe factory is set at C-2, and I tried out A-2 and felt that shift out happened at a much higher rev.
If anyone has experience with different settings & would like to share, I’d appreciate it.
Thanks!
It does show C2 as stock, A2 is only 10* tighter. Ten degrees should be a very small difference. The secondary tension is really more for very fine tuning and backshift. You may get better results setting up the primary first then using the secondary to adjust to small daily conditions changes.
