Farmertyler
Good day, I have a 1994 vmax 500. I have just acquired a skid out of a 2002 sx viper. I am looking for any help or suggestions on the swap.
Thanks in advance!
Thanks in advance!
Maim
Super Moderator
did you get the mounting measurements from the donor sled?
i did this on a polaris using a phazer II skid. measurements i used for it was
centre of drive axle to top of tunnel
centre of drive axle to 1st mount hole (front to back) and then to top of tunnel
centre of drive axle to 2nd mount hole and from top of tunnel down
centre of drive axle to 3rd mount hole and from top of tunnel down. add drop brackets as nessasary.
make sure you compensate for driver diameter unless they are the same as smaller drivers need the suspension moved back on the installing sled. you run out of track adjustment otherwise.
