Johnny20
Can someone tell me after warming up my 1998 Venture 700 Triple, what the idling rpms should be? When I first started it for getting it ready for winter, when it was cold it seem to bog down a little bit and then all of a sudden it started running very smoothly. The idling seem to be a little high to me though and I was wondering what it should be. Thank you in advance
roudyroy1
1500 rpm
Johnny20
Thanks!
A couple of bucks
Did you get it this way? Because if you did, the P.O. turned up the idle to the current RPMs to get it above the pilot circuit.
Johnny20
I am the second owner. Ran outstanding when I put it up for the winterDid you get it this way? Because if you did, the P.O. turned up the idle to the current RPMs to get it above the pilot circuit.
put seafoam in the gas also for the first and very last ride.
