RockSteady
- Dec 15, 2003
Removed carb to rebuild
One question :
What are the 2 electrical wires that go to the carb. for ??
Ed
One question :
Ed
bigbigrichie
tors.... throttle override system its for safety if slides freeze up and cause full throttle it will not let it rev up through ignition system
RockSteady
- Dec 15, 2003
BigRich,
I am sorry I didn't say the sled is a 1986(did they have such a thing back then?), the switch is broken and it seems when you give it gas it dies (then backfires)!
Carb is off sled - should I replace switch (do I really need it??) Should switch be closed(shorted) to run?
Also where can I find a :
8R4-47541-00-00
HOUSING, CHAIN
The one on there has a big hole in the top and back (chain was way too loose)
Used would be great (found one at ronnies' for $150.00)
Ed
8R4-47541-00-00
HOUSING, CHAIN
Ed
bigbigrichie
you can bypass but... safety is a good reason not too
try soldering two wires from carb together it should run
RockSteady
- Dec 15, 2003
Thanks Rich ----
Ed
Ed
