artie_bc
I need to replace one of the handgrips on my 2000 MM700, but Yami apparently doesn't make them any more. Is there any kind of plug and play replacement for them?
HDYAMAHA84
check on ebay or somebody has to be parting one out. im sure theyre interchangeable with alot of sledsI need to replace one of the handgrips on my 2000 MM700, but Yami apparently doesn't make them any more. Is there any kind of plug and play replacement for them?
artie_bc
Does anyone know if a grip from a 2003 would work? Did anything change with the charging system when they changed the ignition?
I have a new Yamaha grip in stock, black in colour.Does anyone know if a grip from a 2003 would work? Did anything change with the charging system when they changed the ignition?
Mine isn't in package, but I think the number started with 8DM
artie_bc
Thanks 74nitro, that sounds like the ones for the newer sleds. I wonder if there's any difference in the heating element from them to the old ones. I'm going to check on Monday if I can get one from my local dealer, and if not, I'll pm you.
