Fuel in Crankcase - How to drain
jcmathis
Central NY
So my center cylinder leaned out on first ride last weekend and melted piston. I am going to replace the pistons, rings, pins and center cylinder as well as clean the carbs to hopefully find the culprit. My old Indy Trail 500 had drain bolts for the crankcase but I cannot seem to locate anything on the viper 700. What is the best way to get the fuel from the crankcase?
Thank you!
