So I am working on a 2002 vax 600 that has the temp warning light on. I have flushed the coolant and even changed out the temp sensor on the top of the engine but the light keeps coming on. Any suggestions on what to look at next or try?
74Nitro
Is it flashing a pattern or just on steady?
74Nitro
It keeps doing that all the time or just when you start it?
If it only does that during startup things are ok. It's just checking the system.
Any thoughts on what this could be?
74Nitro
Can you describe the pattern better?
Water temp circuit problem is 1 long flash 3 short flash
Variable switch for thumb warmer is 3 long flashes, then repeat.
