2002 SX Viper to 2004 SX Viper Engine Swap - DCS Error
xman57
ON
Put my 02 motor in a 04 SX chassis (with DCS) - The motor is solid, starts fine but will backfire and cough and spit.
Removed the tors from the system (shorted it out at the carbs)
Heads up is flashing 6 flashes = DCS sensor error. 02 engine doesn't have DCS sensor in the head, tried to just use the sensor from the 04 head but the same issue occurs - 6 flashes.
Is there a way to remove the DCS activating (Tors like)
Any suggestions would be helpful,
I have checked everything and it all seems to be in order - carbs are clean, no cracks in intake boots (3) power valves are clean, adjusted and working.
