Caperdiesel
So I bought a set of Lightening Adjustable transfer rods off kijiji. I didn't look at the stock ones until i went to replace them. I'm not sure if i'm missing a piece/not the right ones/or i am just blind. The top of the rod is the same, but the bottom of the stock one has male treads on it with a stopper that treads on. The lightening brand has female treads! I bought them to try and get a little more power to the ground. Any help is appreciated.
Take the bolt out of the center of the stock rod, then reuse the bottom section with the new red upper section.
Caperdiesel
As far as I can tell after cleaning it up is its one solid piece, nothing to thread out.
Sorry, didn't look closely at all your pics the first time.
Your rods were already aftermarket.
Now, with the new red ones, you will place the red part into the part in the 2nd pic on the right.
There will be a white plastic washer that goes on top and below the new rod and then a bolt gets threaded into the bottom of the rod.
But, since you already had aftermarket rods, you will be missing that bolt and plastic washers.
I have the same as your red ones, but in Black. You can kind of get the jist of it here.
