Hi guys, any performance single pipes ? Or pipe mods
For single pipe on redhead ?
Vincent
Bore a 2" hole in the baffle of your stock exhaust. Improves flow and sound. Super cheap and easy
Like Vincent said do the bore job. If you want a louder exhaust I do have a dyno-port can for the red heads I’d sell.
There was talk of the viper single pipe being good for a little bump on the old red head. Never tried it myself.
I have done silence mod, reeds, reed spacers, compression increase, ect on my wife's Vmax but she won't let me put tripple pipes on it so I picked up a Viper OEM pipe and a couple different silencers this winter. I have plans on installing it and doing performance comparisons sometime this winter but probably won't get around to it until March and I will post my findings then.
It currently runs pretty strong the way it is so it may be hard to improve on.
pfunctional
Shouldnt have to adjust jetting or clutching for this mod, correct?
If that's all your doing then stock jetting should be fine. I've done 3 of them with no issues.
