Ecm Plug on 97 Mm700
sdviper700
Dell Rapids sd
So I have been working on a 97 mm700 with weak spark. I ended up finding the issue (I think). It had a weak connection at the smaller connector on the ecm. I took the pin keeper out of the connector and found a corroded pin inside, took the pin out to clean it up and in the process broke the connector so now the pin won't stay in. I can't find a new connector anywhere, what's my options? Anyone have a junk sled I could buy the connector from?
Sent from my SM-G986U using Tapatalk
