Viper Ignition Coil Testing
GrimViper02
IA
I have a misfire issue that I believe is either an ignition coil or a stator issue. On my 02 Viper I have 2 coils that resistance test the same but the third coil tests about 25% higher. First 2 coils test at about 11 ohms and 3rd is at 14 ohms (decimal points could be off, i'm not an expect on electrical testing)
From what I understand the coils should all test the same (within 10%). Am I correct that because that 3rd coil tests so much higher it is probably faulty and should be replaced?
Mike
