Hi was working on my Sx Viper today had to clean the carbs and bleed the coolant line well this turned into finding a coolant leak. When I took the coolant bolt off coolant came out it so I filled the coolant revisor and coolant was pouring out from the bottom. What could be my problem?
super1c
Super Moderator
Hi and welcome to site. Not sure what your asking or the problem. Can you clean up your question a bit? Will help figuring out what ya got going on.
I have a coolant leak it’s leaking from the bottom.Hi and welcome to site. Not sure what your asking or the problem. Can you clean up your question a bit? Will help figuring out what ya got going on.
My question is I took my carbs off filled my coolant reservoir up and was wondering maybe my leak was from the carb coolant line since it was disconnected not sure where else it could be leaking.Hi and welcome to site. Not sure what your asking or the problem. Can you clean up your question a bit? Will help figuring out what ya got going on.
of motor or bottle?
of motor or bottle?
Not sure from where exactly but definitely not from bottle
you did put both lines on the carbs i hope. might have come off at other end when you where moving stuff around.
super1c
Super Moderator
^^^^ x2. My first thought. One of the carb coolant hoses leaking or not hooked up.
