vdubracer33
so I think I finally understand turks clutch setup!!! just wondering if its possible one of my stock rivets might be same size as in turks set up so would only have to change 1 size rivet instead of both or not? and where can I find rivets? will try old school hammer approach hopinGB I dont break a weight! also he said 22 40 gearing if I remember right. would just about any yamaha gear fit or does it have to be off of something specific? hoping can keep stock chain too?
Maim
Super Moderator
part # for rivits and their weights are in the tec pages under snowmobile tec. if one rivit is correct, that would help you lots. as to the gears, there was hyvo and non hyvo. make sure you match what you have if you want to re use your chain.
