primary clutch rollers supposed to have a little play?
vdubracer33
New Hampshire
noticed today I can slide the rollers side to side a little. maybe 1/8th of an inch. also noticed the nut and bolt that holds them in also lides back and flrth. on all 3 of them. is that normal or is something wrong
normal. the bolt is in a sleeve that moves in the spider unless you have a clutch with set screws to hold it in place. only ever seen one like that.
Just make sure there’s plastic washers on each side of the rollers and your good.
