Hey guys, I have pretty easy question. I have a 99' MM700. When I bought it, I found out that the previous owner had tried to bypass the oil pump. I have the engine out and will replace the oil pump. With the engine out, I noticed that the fuel pump has a hose that was blocked off with a bolt. I know that there is Fuel in (1), Fuel out (3), Pulse (1), what is the extra hose? What does it connect to?
i know on the vipers from that era, the oil mixed in the fuel pump. so odds are the plugged line is the oil pump input on the fuel pump.
Simonsweden
Oil in. Premix is in fuel pump
