Tjc702
I replaced the drive shaft a while ago because the speedo pin bloke in the shaft. It is a four clog shaft. I was able to remove the old one and install the new one without removing the whole chain case. Now I want to replace the track and can't get enough clearance to get the shaft out. I am trying to remove the whole chain case and it won't come out i removed all the bolts and the parking brake and it is still stuck. what am missing?
super1c
Super Moderator
Easiest way I found so you don’t have to disable the parking brake is to just unbolt collar holding jackshaft bearing on the clutch side. Seeing u did that already the rotor ect is frozen to shaft. Either way just unbolt jackshaft bearing and it will slide over far enough to remove driveshaft.
Tjc702
Still can't get the shaft out. Are the any bolts in the tunnel that is holding it in?
super1c
Super Moderator
If chain case is off and moved out of way. Move shaft all the way toward chain case side the clutch side down and out?
super1c
Super Moderator
That chain case has to be out of the way and shaft out of it.
Tjc702
I still can't get the chain case out. Are there ant bolts in the tunnel that I am missing?
super1c
Super Moderator
By memory 4 bolts hold to tunnel? One at very bottom? That case has to come out. Did u unbolt jack shaft bearing?
Tjc702
I am a dumb ***. I didn't see 2 bolts that were holding the case on. I only found it with a mirror and a flashlight.The case came right out. Thanks for all your help.
