hereismylife
Looks like a bender muffler to me.
			hereismylife
I thought bender only made 3 into 1 for the sleds?
			That looks like a Bender silencer to me as well.
Bender made a single pipe, they called 4x4, and a silencer for use with the Bender single pipe or stock single pipe on the SX Vipers.
hereismylife
Thank you. Do you know if you put that muffler on would you have to rejet?
			The can shouldn't affect your jetting but most people raised the needles 1/2 a position on the Vipers even when they were all stock for mid range cruising as they tend to be lean and have a lot of ignition timing in the lower RPMs.Thank you. Do you know if you put that muffler on would you have to rejet
Lots of info on this if you do a search.
hereismylife
I know about the needles being raised on stock sleds. Thank you.
			hereismylife
I wonder what this is worth if I wanted to sell it?
