zdoerr
- Nov 24, 2021
There’s been an oil leak coming from the pump area which has drained most of the tank over the summer. It looks to be coming out where the cable goes into the pump. Took the cover off to remove the cable and it is full of oil. Wondering if it’s supposed to be?
Thanks in advanced
Thanks in advanced
the 78 340 i have floating around was leaking out of the tac drive until i installed a nos tac kit i found. was only leaking when running though.
zdoerr
- Nov 24, 2021
This engine has a plate covering the tach drive so i know it isn’t coming from there.
