I am installing a 136" suspension from a 1996 600 st into my 95 vmax 4.
I have the rear brackets from the st as well.
Does someone know the distance between the front and rear suspension arms so i can mount this suspension properly.
thanks
thanks
i will have to measure the parts carcass i have at home.
that would be much appreciated.
also wondering if there is the tunnel and 2 brackets in that mounting position, or tunnel and one bracket. Might have to remove the original bracket from the short track vmax 4 to install the 600 st rear brackets?
thanks for your help.
the rear mount is 33.25" back from the middle of the front mount bolt.
i have no idea if it will clear the short track brackets. if it doesnt, they will most likely need to be removed.
