ReaperSRX
I am installing both handguards (Powermadd) and hook on the throttle side, because it looks like i will have to cheat the throttle back a little and with the hook i think i will need a longer throttle lever, any ideas here......is a Viper throttle lever longer and would it fit...........Reaper
Brad
- May 23, 2003
guards
Reaper do you have a pic.I have them on my srx had no problems
ReaperSRX
Brad!
I can get a pic up tonight, but Brad, could post a pic of your set up. what kind of mounts do you have, i was given the Powermad black brackets that go straight out, the instructions show they go between trottle block and handgrip, but there is no room, i either have to move throttle block back or move grip foward........Reaper
Brad
- May 23, 2003
guards
Reaper that is right it goes between the grip and the throttle, loosen the throtle block then slide it over and once the bracket is in place slide the throttle block back against the bracket.That is what i had to do
ReaperSRX
Thanks Brad, that's what i have done, but i kept the throttle block in place and moved the grip, because i was also installing hook, i just slipped the excess hand grip over the hook and voila, looks pretty good, but i still feel the throttle might be harder to get at when i hang off the sled sharp corners...............Reaper
ReaperSRX
Do the handguards interfere with the hood, can you open and close with them on...........Reaper
