Wreitzloff
- Dec 6, 2021
Hello I am new to this forum so hopefully I am posting in the right place.
I have a 91 phazer 2 that I need a new set of carbs for I found a set for sale that look to be off of a phazer 1 they look almost identical to mine as far as I can see from the pictures. I was just wondering what are some differences from the two machines. Will it run fine with this set. And if I find a phazer one at the junkyard will I be able to use parts off of it on my sled. Thank you.
you should be ok with the carbs as the engine is pretty much the same.
Someone will have to confirm but I think the carbs are different as the 2 little rubber plugs go in different holes on the Phazer 1 and 2. Even though they are different they should both work. Also the front suspension is a little different. I'm not sure if they use different parts but they definitely are backwards from each other. The phazer 1's have the link on the rear and the 2's have it on the front. If you're not sure if a part is the same what I do is go on partzilla.com, open 2 tabs and compare the part numbers
