heelcliker Q?
sxtuner
man. can.
hellow, I talked with bender and they said I coulden"t pull the heelclikers. I used to be abel to with the original set they first came out with so why not now? I have a 99 600sx, bender pipes, trail ported .
I can pull them with my 600 just leave them empty and run a little shallower finish angle on your helix. I 'm running bender pipes at about 8700 with a 45/39 helix!
i think you can pull them also , like sxryan said leave all the holes empty , run it and make your adjustments to the shoulder , i like to use one gram in the tip for alittle more POW out of the hole ..the only problem i had with leaving them totally empty is the belt slipped , but i run a 136 x1 3/4 track also ....
I also had a problem with the belt slipping,went to the green sec. spring now it hooks up awesome, and yes adjust the shoulder weight to adjust engagment rpm. I also put in 15mm rollers for proper clearance of the weights
