Drwe
- Nov 28, 2021
I've just replaced all the idler bearings, and when reassembling the rear idlers/tensioner, I notice that the clutch side outside idler bearing overhangs the start of the thread. Is this the way it should be? I have washers on either side of the tensioners as shown in the parts diagram.
Pics: https://drive.google.com/folderview?id=1brlqs1S6DC1EXIu70-MQNn_qFuydeirk
Yes, it needs to be like that or it won't jam everything tight. The washers should be on both sides of each rail, not the tensioner.
