Saffoto
So I’ve already drained and replaced the oil, now I want to adjust the chain tension without having to remove the cover. I know how to do it, but I’ve seen different opinions on how tight it should be. Some say to finger-tighten the bolt, and that should be pretty much the correct setting, others say to add 1/4 turn and others say to remove a 1/4 turn after finger-tightening. I also want to know if this should be done when the sled is cold, if it should be warmed up, or if it makes no difference. Thanks!
Spec says finger tight then 1/4 turn back, then lock the jamb nut.
Saffoto
ThanksSpec says finger tight then 1/4 turn back, then lock the jamb nut.
