Bigyamaha87
- Dec 12, 2021
So...i finally got the viper back to get and going. Runs great...except it burbles when just crusing from 1/8 to about 1/4 throttle. Fuel screws at 1-7/8 which is factory spec? Any ideas why it would burble? Maybe go 1-1/2 ?
			mod-it
Does it idle smoothly and pick up from idle with no issues without the choke on?  And comes back down to idle rpm without any hanging rpm?
Need to determine if it is from being too lean or too rich.
Bigyamaha87
- Dec 12, 2021
Yes idles smooth...just tried fuel screws at 1.5 idle did hang  then, still had that burbly sound just off idle at 1.5 turns out. Back em out to 2 turns again
			Bigyamaha87
- Dec 12, 2021
Just noticed my manifold is cracked in 4 spots at y. That wouldnt cause it to burble would it? With air being sucked in?
			not in my experiance.
dad has the 05 sx venture with the same engine. it always burbles/gargles/loads up when it is ridden slowly. when i hear it gargling, the next straight or lake i open it up and get it cleared out.
		super1c
Super Moderator
Yup totally normal, keep fuel screws at 2 turns out.
			Bigyamaha87
- Dec 12, 2021
S
			So its totally normal for it to burble at low speeds?Yup totally normal, keep fuel screws at 2 turns out.
How many miles are on it? Is it hard on fuel?S
Bigyamaha87
- Dec 12, 2021
Little over 5000 miles. Have not gotten to ride it to much so far...not sure yet on fuel consumption. But what little i did ride midrange was annoying with a burble.How many miles are on it? Is it hard on fuel?
The first thing I would do is change out the main nozzles. Contrary to what most think, this is a wearing part and need to be replaced with age and miles. Number 25 in picture.Little over 5000 miles. Have not gotten to ride it to much so far...not sure yet on fuel consumption. But what little i did ride midrange was annoying with a burble.
				2002 Yamaha SXVIPER ER (ELEC START) (SXV700ERG) Carburetor
Shop online for OEM Carburetor parts that fit your 2002 Yamaha SXVIPER ER (ELEC START) (SXV700ERG), search all our OEM Parts or call at 269-385-1540
				 www.cyclepartsnation.com
				Bigyamaha87
- Dec 12, 2021
Shop online for OEM Carburetor parts that fit your 2002 Yamaha SXVIPER ER (ELEC START) (SXV700ERG), search all our OEM Parts or call at 269-385-1540www.cyclepartsnation.com
Bigyamaha87
- Dec 12, 2021
I was just reading other posts about main nozzle wear. This was going to be my next step. Thank you!
			first thing to do is get the manifold off and weld it top and bottom or your going to burn the engine down, it will be cracked both top and bottom!
			Bigyamaha87
- Dec 12, 2021
Already done....the sled seems like it uses a lot of oil. Oil pump failure? Causing it to run rich? Oil cable is set at 20mm.first thing to do is get the manifold off and weld it top and bottom or your going to burn the engine down, it will be cracked both top and bottom!
What is it per liter of fuel?
			check how much oil it uses on a ride. mark the bottle with a sharpie marker and recored how many miles you go. then using a ratio rite cup or other unit of measure record how much oil you put back in to bring up to sharpie mark on bottle. When the pumps go bad they do go full rich but I have not seen alot of bad yamaha injection pumps. Does the sled have a bar riser on it??Already done....the sled seems like it uses a lot of oil. Oil pump failure? Causing it to run rich? Oil cable is set at 20mm.
Bigyamaha87
- Dec 12, 2021
Ok will do. No no bar riser. I put 130 miles on it tank was full it is now halfway pointcheck how much oil it uses on a ride. mark the bottle with a sharpie marker and recored how many miles you go. then using a ratio rite cup or other unit of measure record how much oil you put back in to bring up to sharpie mark on bottle. When the pumps go bad they do go full rich but I have not seen alot of bad yamaha injection pumps. Does the sled have a bar riser on it??
ya..wow, if you used half a tank of oil in 130 miles, your full on rich! which makes the sled run leaner on air/fuel ratio. I would definitly look into the pump replacement if your sure the cable is adjusted correctly and the cable is fit back into sleeve. At least theres less mosquitos around...lolOk will do. No no bar riser. I put 130 miles on it tank was full it is now halfway point
Bigyamaha87
- Dec 12, 2021
Yes cable is in the sleeve.. adjustment at 20mmya..wow, if you used half a tank of oil in 130 miles, your full on rich! which makes the sled run leaner on air/fuel ratio. I would definitly look into the pump replacement if your sure the cable is adjusted correctly and the cable is fit back into sleeve. At least theres less mosquitos around...lol
