Andris
Hello. Got problem with phazer. No spark on both sides. Stator measures right. Was replaced 2years ago. Tried new ignition coil and CDI unit. Tors bypassed. When crancking with starter I do get voltage on orange wire to ignition coil, but no spark. Spark plugs caps 5 ohm measured.
Any suggestions appreciate.
Thanks.
Thanks.
did this myself today, is kill switch up?
Andris
Yes. Checked with multimeter. Main switch, kill switch open loop. I do get voltage on orange wire to ignition coil, but no spark. Also I checked continuity engine to black stator wire and it's good.did this myself today, is kill switch up?
Thanks for reply.
NorthofSixty
Have you checked ignition coil resistance, coil ground, plug wires, plug caps?
Andris
Yep. I put new ignition coil. Spark plugs caps 4.9 ohmHave you checked ignition coil resistance, coil ground, plug wires, plug caps?
good ground to chassis from engine? seen this cause issues on old enticers.
Andris
Hello. Thanks for helping. Ended new ignition coil was faulty.good ground to chassis from engine? seen this cause issues on old enticers.
