JohnnyG383
Please help looking for track tension specs On a 2003 SX viper 700 I have searched for over an hour and cannot find what the factory specs are for how tight the track should be set please help thank you
Yamaha spec - Lift back end off ground. Should have 25-30mm gap between the track clip and slider when pulling down with 10KG of force.Please help looking for track tension specs On a 2003 SX viper 700 I have searched for over an hour and cannot find what the factory specs are for how tight the track should be set please help thank you
About half way up the rails.
(Doesn't need to be exact, track should not hang loosely with back end off ground.)
