TheFarm845
- Sep 13, 2021
Anyone have a good bottom end for a 2000+ SRX700 or a good complete engine? My case got water in it from sitting and has since frozen solid. Seems that rebuilding them costs more than just finding a used engine.
700 Viper bottom end crank and cases will work as well.
TheFarm845
- Sep 13, 2021
No modifications needed?? And the SRX jugs will bolt right on?700 Viper bottom end crank and cases will work as well.
No modifications necessary and the ignition, recoil ect will bolt right up.
The SRX cylinders also bolt right up with no modifications and stock base gasket.
The 700 Viper crankshaft is a different style[pork chop as opposed to full circle] and a lb or two lighter then the SRXs but the bearings, rods, pins stroke ect is all the same.
I actually ran a Viper crank in my 2002 SRX to try to pick up some extra ponies but I never noticed any difference.
we actually noticed that the srx bottom end was stronger when we used it in a viper.
