Hi, trying to move a rear suspension from a 99 venture 600 to a 2001 srx 700. Took measurements from a 97 venture 500 and I cant get it on. Does anyone here have a venture 600/700?
Johnny20
I have a 98 700 Venture Triple
05 venture 700 at home in yard atm.
That will do. Distance from center of bolt that is under the secondary to the middle bolt that holds the rear suspension. And the the length from footboard to the center bolt (height). And the length from center bolt to the uppermost bolt of the rear mounting triangle, and the height from that footboards to that bolt. Thanks05 venture 700 at home in yard atm.
kk at work and not home until after midnight and rather do it in daylight
Thanks, but I got a message from my mechanic now he had gotten the measurements and the 99 venture 600 rear suspension was installed in my buds 2001 extended srx 700. Also has engans gas shocks, which is good, because he is like 275 lbs.
