Mark2stroke
- Feb 16, 2022
I replaced my drive bearings in my SXR 700 and when I removed chain case housing 2 spacer fell off. One is wider than the other, which one goes on jackshaft and which one goes on driveshaft. Thanks!
The easiest way to tell is install the gears and spacers only and place the spacers in the positions that allow the top and bottom gears to line up perfectly for the chain to run straight and not be kinked. It will be obvious which spacer goes where.
I think the top is the wider.
I think so too but not positiveI think the top is the wider.
Go to a parts site, like yamaha parts house, or a site like that, then you can look up your sled, and see the parts diagram for the chaincase.
That’s how I do it every time I take a chaincase apart. It will show the spacers, and which order they go in.
