RX1 track suspension swap NIGHTMARE ... swap to (ski-doo sc-10)
Olieland
Did someone , done a sc-10 suspension swap on a rx1 2003?
Everywhere i look... people done it magically with a little tap on the shoulder from other people.
Everybody tell's me ...(bolt on!) ...eaSY shit!
I started yesterday at 3pm ... after i realised the scond shaft , the one who go in the drop plate is too large... so ok.. i remove my seat ,,, drill the rivets of the drop plate...and i bolted the plate inside out...and the shaft go right in his place..but!
All the suspension is not good positioned...to much at front.. the trac have a big slack in the back... and i cant connect the front shaft to the body of the sled
If i try the front of the track gonna hit the track gear...
So...i need the measurement to drill the hole at the wright place .. to position the track at the right place ... and if someone have
good pics with the measurement .. good i will climb to paradise witout touching the snow
FOr the drop plate...i know its not good enough ... i try it to see if the sc-10 fit bolt on...
