89 phaser jetting and clutching questions/help
yamahapower10
so I have a 89 phase deluxe with a AAEN can on it and its bored a bit and I am not sure what jets re in it right now because the previous owner did not know so, I bought 150 main jets, new plugs, but I cant find any 110 pilot jet and so if ya know where I could find some let me know. But I'm more curious about what i need to do for clutch springs, weights, and what nozzles will help with the midrange lean. I'm very new to clutches and don't know to much.
It would benefit you to use the heavier Exciter weights, or even the "1990" and up Phazer weights aren't too bad. Those 8V0 weights always just wanted to rev but not go anywhere. Also gear up one tooth on top believe it or not. You need to also get the engagement up to at least 4200. You will be amazed how much those two things will help. If you want to try more two degrees steeper cam angle will help as well.
