snowman_959
- Nov 8, 2021
2000 yamaha mountain max 700, all stock expect for mbrp trail can, slydog trail skis, and kimpex seat, and jetting. i ride sometimes -30°f to 44° above close to sea level and even drove to 1000° lol. The jetting on it right now has 128.8 on all mains and 62.5 pilots. i did get new jets. 147.5 MJ 1 and 146.3 MJ 2 and 3 with 45 pilots and the sled didn’t want to start. swapped back to old jets and started and ran fine like it did before. is the jetting correct or is there something i’m missing. thanks in advance!
snowman_959
- Nov 8, 2021
also fuel screws are backed out 1.5 turns
MURDER YAMAHA
VIP Life Member
What are the needles at?
Maim
Super Moderator
any porting done to it?
snowman_959
- Nov 8, 2021
i have yet to check the jet needles but i haven’t done it before. also i don’t think there was any porting done to it either
MURDER YAMAHA
VIP Life Member
Gotta know what the needles are for sure. Very important. Look around in the tech section for info how to get them out.
Carb Needles
totallyamaha.com
74Nitro
The Yamaha manual calls for #50 pilots and mains #145, 143.8 at -20F and elavation of 1700-3300
MNMead
I'm wondering how you haven't burned down with your jetting. 62.5 pilots seem way fat for sea level. I couldn't even get my sled to start on 62.5s it was so rich. Dropped to 55's and it fires right up and idles clean.
MURDER YAMAHA
VIP Life Member
I’m sure it was last jetted for the mountains.
MNMead
I don't mean to hijack, but this brings up a question. What is the logic on the larger pilots for altitude? I read on a MX forum that at altitude there is not enough... negative pressure? to pull the proper amount of fuel through the smaller pilot jet, so they recommended going larger since less restriction would allow more fuel to flow. But it would not flow at the max capacity of the jet at altitude. I haven't read this anywhere else nor seen it reflected in jetting charts so I am wondering if this is true or not.
74Nitro
It's true. Less vacuum created with the different air so need larger pilots.I don't mean to hijack, but this brings up a question. What is the logic on the larger pilots for altitude? I read on a MX forum that at altitude there is not enough... negative pressure? to pull the proper amount of fuel through the smaller pilot jet, so they recommended going larger since less restriction would allow more fuel to flow. But it would not flow at the max capacity of the jet at altitude. I haven't read this anywhere else nor seen it reflected in jetting charts so I am wondering if this is true or not.
74Nitro
I also am surprised you haven't burned it down. Hope you weren't holding it too long.
sideshowBob
That sled had safe jetting for around 10,000 ft ASL!
I would start with a complete disassembling and cleaning of the carbs...don't forget the little top hat filters hidden under the float needle and seats.
As stated check the slide needles clip positions as well as the size stamped on the needle tubes.
Put everything back to stock settings found in the tech section and you should be good to go. These Red Heads typically are very forgiving when it comes to carb settings as long as they are not too lean.
snowman_959
- Nov 8, 2021
I will try and check the jet needles tomorrow. i was looking at info on jet needles and seen there is a screw on mag side. some said not to mess with it, so do i just check the other 2?
MNMead
No you need to do all three. Just work around the brass screw. Should only tak 10 minutes to do all of them.
