Hey guys and gals,
The crank crapped out on me last winter and of course I pulled it home and ripped into the motor like a savage bear in a picnic basket...well fast forward some months and now I'm putting it back together and for the life of me I cannot remember or find a diagram showing where the 6 longer heads bolts go. Anyone have a link or the knowledge of their locations.
Thanks!
Thanks!
Test fit the bolts in the holes without screwing them in...it will be obvious where the 6 longer and 12 shorter bolts should be by the space between the bolt flange and cylinder head.
Thanks, I will give that a try this evening.
Yep, that’s how i do it as well, lol
They go in the middle row, in line with the dowels on the left and right side. If you look at the holes in the cylinders you will notice there are less threads due to the dowels, hence the longer bolts.
Yamablue
What 74Nitro said. Middle row / dowel holes are the longer bolts.
