kartman
2000 srx. Was running fine and parked last month. Attempted to start and have no spark. It does have electric start and will spark the plug one time on initial attempt but nothing after that. I checked every connection, pulled the harness from under engine, checked every wire and re-wrapped it. Unplugged kill switch, and i cleaned the flywheel and pickup. What now? stator? cdi ?..... just o
dd that it was fine when parked and now its dead... just trying to get this back together for the kid.....thanks !!
dd that it was fine when parked and now its dead... just trying to get this back together for the kid.....thanks !!I believe the 2000 SRX has a white load relay above the left footwell....you can try removing it and see if it will start otherwise I know a kill switch, and wiring harness issues will act like that but since you have already checked the usual suspects I would check the stator next.
