Holenov
was cleaning my carbs today and noticed the plastic L fitting going into the middle carb is broken. I can't find a part number for them. Someone must of ran into this before ?
Post a pic, usually have to get the stuff used off a parts sled.was cleaning my carbs today and noticed the plastic L fitting going into the middle carb is broken. I can't find a part number for them. Someone must of ran into this before ?
Have you looked in the parts finders? I dont think thats a replacement part but I think that pressed in. Could try to get a used carb rack and see if you can pull one.You can see where the white L connector is broke between the line and the carb
