01sxr700
As the title says the pto cyl is missing on high rpm, runs good at low and mid range. Checked plugs all good.
Fresh rebuild on engine top end.
Compression is 120/120/105, The one cyl is low because of the lower compression ratio on the pto cylinder.
Dry/wet compression test same result.
Interchanged coils to check coil, same problem.
Full throttle run, shut the engine off with throttle wide open and the pto plug is wet and the others are dry and brown.
Do the same thing at mid range and all the plus are dry and brown.
Checked the crank seal with starter fluid and no change in rpm.
Checked carbs/clean, and because the plug is wet it would indicate its getting fuel.
Checked for grounding out of wire from CDI to coil all indicate good.
Reeds are good
Power valves operating the same.
Anyone have any insight to my problem?
Reeds are good
might be time for a new set of reeds.
01sxr700
I could try interchanging them with another cylinder.
These carbs vent into the airbox so make sure all the hoses and fittings are in good condition, especially for that cylinder.
Is the machine completely stock?
01sxr700
Yes stock.
try moving the reeds around and see if it moves cyl
01sxr700
Just did that and will test tomorrow.
01sxr700
So I put it back together after moving the reeds to the center cylinder and cleaning the pto carb. Now it runs like a champ, the only other thing I did was unplug and replug in the cdi to check the wires going to the coils for a short to ground. Go figure. On another note anyone know which weight goes non the inner hole of the clutch weight. Machine is revving at 9,000.(I remove a the rivets when it wasn't getting the proper rpm not realizing it wasn't firing at high rpm). The manual says one thing and the tech page on the site say another.
13.9 rivet in both holes of the weight
