Will that help the primary to grab the belt better? It's touching it with silk gloves.. How about a roller change or are the stock ones that give the most squeeze?
A smaller outer rivet when combined with a larger inner will lower rpm,s & give better back shift, acceleration & belt squeeze then loading the tip. Try a 4.5 gram inner with a 2.4 outer to start with.
