Matt Braap
- Sep 6, 2023
Maim
Super Moderator
8dn are 2 grams lighter base weight than the ones that came stock in your sled. they can be made to work with tuning time.
i think that you should make sure what primary you have as there are short cover and long cover ones. they use different weights and springs.
when i did my sx500r, i used 40 gram aftermarket (thunder shift) base weights as they use washers and screws to add weight, where the stock ones only used rivits witch are harder to rune with.
Matt Braap
- Sep 6, 2023
Matt Braap
- Sep 6, 2023
Thank you. This is my first sled. I’m fairly mechanical, yet I have a lot to learn about clutches. I didn’t realize there were short and long cover ones. Here’s what I have
Matt Braap
- Sep 6, 2023
Maim
Super Moderator
that looks like a short cover clutch. you can put a tall cover on it to use tall cover combos.
the 8ab was a very popular when doing clutch mods on the twins back in the day and there are some good user set up's in the tec pages.
i went with aftermarket for easier tuning as the set up i used used 8ab weights.
Matt Braap
- Sep 6, 2023
Thanks much !
74Nitro
I used 8DN-20's in many 600's with both heavy rivets. You may have to fine tune a little. They were used in 2000-2002 SRX 700
Your engine has max power at 76-7800 RPM.
Make sure the rest of your clutch(s) is in good condition.
The short/long cover choice only affects springs. No impact on any weight choice.
Matt Braap
- Sep 6, 2023
Good to know, thanks a lot for responding! Do you know if any other good replacements that may be available?I used 8DN-20's in many 600's with both heavy rivets. You may have to fine tune a little. They were used in 2000-2002 SRX 700
74Nitro
Weights?Good to know, thanks a lot for responding! Do you know if any other good replacements that may be available?
Matt Braap
- Sep 6, 2023
Yes, replacement weights. Don’t seem to be any 8CA available
Maim
Super Moderator
get in touch with the guys at thunder products as they should be able to find a 40 gram base weight that would work for you.
Matt Braap
- Sep 6, 2023
Thank you
