Power Valve power
stevek61
I have a 2002 Viper that I removed the elec start and battery from. Now I dont seem to have power to the PV servo. I'm thinking I can run a new wire from accessory power to the servo but I am not sure what wire powers the servo. I'm thinking its the white with red wire that is alone in a connector at the servo. Can someone who has a Viper with es verify that that wire is power. When you turn on the key the servo power should be activated. If the white with red wire is the correct one it should power up when you turn on the key. Thanks for any help.
