GasCans
Just took the carb rack out of a 98 SRX to clean it up and have a couple questions.
1.) After I clean and reinstall the rack, is there a specific procedure needed to bleed the coolant reservoir. I'll need to add some coolant as it puked some out the clutch side of the carb rack when I disconnected the coolant line from the carb rack.
Appreciated any answers on this. Thanks
No.Just took the carb rack out of a 98 SRX to clean it up and have a couple questions.
super1c
Super Moderator
Don’t have to bleed anything. Just top off overflow!
GasCans
Thanks. I completed the carb rebuild on the weekend, replaced the old fuel with some fresh 94, primed it a couple times and fired off the SRX in two pulls. Topped off the fluids and it runs just excellent now with easy starts and crispy throttle response. Now to get the SX Vipers done.
