Spark issue
yammynutz
London On
What would cause a no spark issue but when cranking with the key, the headlight glows. Could this still be a stator?
just had a doh! moment. check for spark while cranking with key and by using pull start. seen an old doo loose spark when cranking with key before. buddy reached in and had it fixed before i discovered what was doing it.
