fullcoda
A couple of questions. Do these bearing pins just roll down into the pockets? I think I can get away with a slightly bent connecting rod, as the wrist pin will still be straight on the perpendicular plane. Thoughts? It's the only crank that i could use. I know that even if someone could find the parts, I dont believe that a crank is rebuildable. looks like factory pressed. Any help would be appreiciated.
bird
- Feb 28, 2022
Running a two stroke with a bent rod is going to throw off your port timing. I would not even waste the effort of putting the engine back together and then risk ruining the crank case and cylinder.
There are companies that rebuild those crankshafts.
