98_vmax700
- Dec 13, 2023
I ended up getting some psi pipes and I am having a hard time finding any Info on jetting and clutching I am running at +600 elevation
MURDER YAMAHA
VIP Life Member
I may have some info, are they end dumps?
PSI not Power Inc.I may have some info, are they end dumps?
MURDER YAMAHA
VIP Life Member
My bad.
My reading comp. Skills have always been fairly low…lol
98_vmax700
- Dec 13, 2023
Yeah I don’t see anything about psi pipes there
stock pilots (45)I ended up getting some psi pipes and I am having a hard time finding any Info on jetting and clutching I am running at +600 elevation
fuel screws - 3 turns out
stock slides
stock nozzles
needle- 3rd/ 4th/ 4th/ pos.
main jet- 142.5/ 142.5/ 142.5.
pto/ mid/ mag./
all i have for clutching is for the short coverI
stock weights-(8ch 42.5 grams)
stock sec. spring (green)
sec.cam (52/42)
sec. setting ( 6-1)
shift out-9100 rpm
primary is a special psi spring- green. you'll have to figure that out . i dont know what its rate is. also 8ca wieghts work well with this setup
also 15 mm clutch rollers
