700sxvermonter
I just cleaned the carbs and changed the reed petals because I had some reeds that were no good. Before I did this I noticed some low rpm bog and now even after I did this I am still noticing some lower rpm bog. Once I get up little higher in the rpms it runs great. What am I not doing right? Plugs are new, fuel is fresh. It seems to be a little more smokey then usual too. Any suggestions would be great. This is the first time I have ever cleaned the carbs so I imagine I'm missing a important part. Maybe the float is sticking and I'm getting too much fuel at idle? I live in upper New England so I'm trying to get this corrected before the real snow actually gets here
thanks in advance
How many miles on the sled?
Is the fuel mileage good or bad?
Are the exhaust valves in good working order?
You can remove the servo motor cover and watch to see if its functioning properly.
700sxvermonter
The Speedo stopped working around 2400 miles I'm guessing I got about 4000 on it now. Fuel mileage seemed to be ok last time I rode it. I cleaned the power valve and they seemed to be working good in my opinion. I have not checked the servo motor yet. Thank you for the suggestion on what to checkHow many miles on the sled?
might be failed oil pump but that can only be checked by oil useage while riding.
Sticking and/or worn clutching, old belt, wrong belt tension can create a bog as well.
700sxvermonter
I'm going to replace the belt. It looks in good shape but I can afford to put a new one on it so I will. Thanks for the suggestionSticking and/or worn clutching, old belt, wrong belt tension can create a bog as well.
