Buffalo
The raised collar spacer goes on the driveshaft first with raised edge against the chaincase bearing and the flat spacer goes on between the lower gear assembly and the raised spline section of the the insert.
Most of us that work on numerous sleds use the parts microfiches off of parts suppliers like Partzilla that are very usefull to determining assembly order of parts.
Buffalo
Thank you! That was exactly what I needed.The raised collar spacer goes on the driveshaft first with raised edge against the chaincase bearing and the flat spacer goes on between the lower gear assembly and the raised spline section of the the insert.
